You are here: PSPad forum > English discussion forum > Re: Weird highlighting problem
Posted by: bluezero | Date: 2018-12-28 14:39 | IP: IP Logged
I noticed some weird highlighting problem when selecting some part of the code then the syntax is wrongly highlighted, here is an example:
Before:
i.gyazo.com
After (PHP):
i.gyazo.com
After (HTML Multihighlighter):
i.gyazo.com
I did not have the problem in 4.x.x, only in 5.x.x
Hope you will be able to fix it.
Thank you
Edited 1 time(s). Last edit at 2018-12-28 14:39 by bluezero.
Posted by: pspad | Date: 2018-12-28 22:38 | IP: IP Logged
There is combination with highlighting syntax, highlighting cuttent line and selecting text.
I don't see nothing wrong. Can you exactly write what do you consider as wrong highlighting and how it should be in your oopinion?
Posted by: bluezero | Date: 2018-12-29 15:37 | IP: IP Logged
look at the commented out code, beginning from line 606.
Its correct on the first image, but not correct on the 2nd and 3rd.
The only difference I made is the selected variable on line 600, then the commented out code changed the color.
Posted by: bluezero | Date: 2019-02-26 09:52 | IP: IP Logged
This was fixed in 5.0.1 (310)
Thank you
Posted by: bluezero | Date: 2019-02-27 14:47 | IP: IP Logged
Hm, actually it still has problems.
1999-2000 Lines have proper color, but
1992-1982 do not, That only happens if i have variable highlighted $aFiles in this case.
