You are here: PSPad forum > English discussion forum > Re: FORUM'S DATE FORMAT
Posted by: Gabriel_ACE | Date: 2018-12-17 16:10 | IP: IP Logged
WHY?!?!??!!? T____________T
why forum use MMDDYYYY ??? It ins't logic!!
there is a way that I can see the date in a correct formar? like YYYYMMDD OR DDMMYYYY ???
Edited 1 time(s). Last edit at 2018-12-17 16:10 by Gabriel_ACE.
Posted by: Andreas | Date: 2018-12-17 16:53 | IP: IP Logged
This can be set in your forum settings.
Posted by: vbr | Date: 2018-12-17 16:57 | IP: IP Logged
Gabriel_ACE:...
why forum use MMDDYYYY ??? ...
the formats depends on the regional setting of the forum
it seems, the mentioned date is (for some reason) connected with the item:
Language: English (American)
You can adjust this setting to suit your needs better:
On the forum page:
MY ACCOUNT [...]
My Control Center
Edit My Profile
Change the item:
to
English (dd-mm-yy)
or
English (yy-mm-dd)
and click
[Submit]
hth,
Posted by: pspad | Date: 2018-12-17 18:00 | IP: IP Logged
I will set YYYY-MM-DD as default format instead of the American format. But you can change it in your profile
Posted by: Gabriel_ACE | Date: 2018-12-18 13:25 | IP: IP Logged
THZ! TO EVERYONE!!!
