You are here: PSPad forum > English discussion forum > Re: Problem with Project display
Posted by: Neil | Date: 2018-10-07 20:25 | IP: IP Logged
Hi Jan
Finally using "Projects" after all these years (should have started using them years ago !!)
Anyway I have a problem with display.
At home they work fine (win 10)
At work the line I select gets blanked out !! (win 8)
I can still use Projects as PSPad knows the file and will open it ok.
It's just annoying to look at.
Any clues ??
Thanks
Neil
Posted by: Neil | Date: 2018-10-16 04:13 | IP: IP Logged
Hi Jan,
New computer at work - Win10.
Works fine now.
Cheers,
Neil
