You are here: PSPad forum > English discussion forum > Re: can not start typing at column 0 on new line or file open text file
#1 can not start typing at column 0 on new line or file open text file
Posted by: mydna | Date: 2018-09-14 16:09 | IP: IP Logged
I am certain that I once found the setting to be able to start typing a character on column number 0 when you create a new text file and click anywhere on the line or in an opened file.
But instead the cursor remains where you left click on an active line and typing will begin where the cursor is along the line.
How do you set it as any text editor where anything you type begins at the beginning of the line at column 0, and the cursor always begins at column 0 too when you click on an active line?
Am I making any sense?
#2 Re: can not start typing at column 0 on new line or file open text file
Posted by: vbr | Date: 2018-09-14 20:37 | IP: IP Logged
mydna:
I believe, you have to uncheck the respective setting:
Program Settings: Editor (part 1): [ ] Scroll past EOL and EOF
(Granted, this label is not very descriptive...)
hth,
