You are here: PSPad forum > English discussion forum > Re: XML Kills Beta
Re: XML Kills Beta
#1 XML Kills Beta
Posted by: arkieguy | Date: 2018-09-11 14:35 | IP: IP Logged
I've updated my copy of PSPAD to the beta version and every time I go into an XML file, PSPAD completely locks up (it doesn't even display the XML first).
I've tried uninstalling (and deleting the entire folder) and reinstalling from the installer and then applying just the 32b beta patches as well as the 32b and 64b patches. Same result.
#2 Re: XML Kills Beta
Posted by: pspad | Date: 2018-09-11 17:14 | IP: IP Logged
What PSPad version do you use? Th current 5.0.1 build 283?
Can I have any XML file what causes PSPad lock?
