You are here: PSPad forum > English discussion forum > Version 5.0.0: Run after compilation runs always twice
#1 Version 5.0.0: Run after compilation runs always twice
Posted by: losgehts | Date: 2018-08-28 14:29 | IP: IP Logged
I love PSPad and just updated it from version 4.5.4 to version 5.0.0 (24.04.2018 32b).
With the new Version I have thie following problem:
When I hit CTRL+F9 to compile and run my fortran code. The code will be properly compiled, but the fresh compiled program runs twice (and this causes problems).
In detail:
I use the Highlighters settings for the Compiler for "Run After Compilation"
cmd.exe /k %Name%.exe
and this command is executed twice after compiling (two cmd-windows open).
Has anyone an idea what I can do that the command will only be executed once?
That is my full fortran highlighter setting:
Quote:
[Fortran]
Filter=Fortran Files (*.f;*.f90;*.for)|*.f;*.f90;*.for
HLTabWidth=0
IndentChar=
UnIndentChar=
Compilator File=c:\Program Files (x86)\Intel\Composer XE 2013\bin\ia32\ifort.exe
Compilator Param=-traceback -check:all -warn %Name%%Ext%
Compilator LOG=%Name%.Log
Compilator Run=cmd.exe /k %Name%.exe
Compilator Help=
Compilator SaveAll=1
Compilator ParsLog=%F(%L)
Compilator Capture=1
Compilator HideOutput=0
Compilator DefaultDir=
Compilator LogType=0
Comment=00FF00001FFFFFFF010
Identifier=1FFFFFFF1FFFFFFF000
Number=1FFFFFFF1FFFFFFF000
Reserved Word=1FFFFFFF1FFFFFFF100
Space=1FFFFFFF1FFFFFFF000
String=000080001FFFFFFF000
Symbol=1FFFFFFF1FFFFFFF000
HLRealTabs=2
RightEdge=72
DocComment=
CurrentLine=0
CurrentLineBack=65535
Compilator CompileOnBackground=0
Compilator ProgSaveAll=0
Compilator ProgRunSelection=0
When I use the version 4.5.4 with the same settings it works as expected.
Regards,
Ulrich
Edited 1 time(s). Last edit at 2018-08-28 14:31 by losgehts.
