You are here: PSPad forum > English discussion forum > Re: External programs limited to 5
Posted by: brolx | Date: 2018-08-28 08:56 | IP: IP Logged
Would it be possible to increase this number, it's so useful?
Thanks a lot
Posted by: pspad | Date: 2018-08-28 09:14 | IP: IP Logged
Limit for 5 tools is for project or for highlighter (language)
In the left favourite tab you have possibility to unlimited external tools.
Posted by: brolx | Date: 2018-09-06 12:06 | IP: IP Logged
It's the limit for highlighter that blocks me. 5 is very low!
Is there any reason to such a limitation? If no technical problem, why not to increase it to something like 20?
Posted by: pspad | Date: 2018-09-06 13:08 | IP: IP Logged
Can you write me any example when you will use 20 (more than 5) external application for one highlighter?
Posted by: brolx | Date: 2018-09-07 08:58 | IP: IP Logged
I have specific config files where I want to launch various batch files like syntax checks, regex search in all sub-directories, etc.
I need at least 8 programs.
This is my specific needs but I'm sure others may have plenty of other reasons to require more than 5.
Posted by: pspad | Date: 2018-09-07 09:11 | IP: IP Logged
In my first answer I told you, that you can have any count of external programs in the left favourite tab.
I think it can be suitable for you.
Posted by: brolx | Date: 2018-09-07 11:35 | IP: IP Logged
1. By copying the exact same entries as in highlighters, it doesn't work!?!
It's a BAT, not an EXE; is this the problem? No idea.
I suppose it'll be possible to troubleshoot this...
2. As I have many external programs, putting all highlighters together gives a huge list, which isn't very handy
3. The tool panel is much more obtrusive than the control buttons
