You are here: PSPad forum > English discussion forum > Re: Is it a bug or feature?
Posted by: garbuya | Date: 2018-08-16 17:49 | IP: IP Logged
My text is colorized as SQL
I noticed that if you position a cursor BEFORE last closed bracket and try to type another closed bracket PSPad will not do it!
You have to position a cursor AFTER this bracket
For example: Initial text is
NVL(ORD_DT,SYSDATE)
I changed it to be
NVL(ORD_DT,TRUNC(SYSDATE)
Now I positioned cursor before ")" and tried to type another one.
Nothing happened. Another closed bracket was not added.
I have to move a cursor after ")" in order to add another closed bracket
This occurs all the time with all types of closed brackets - ")" or "]" or "}"
Posted by: pspad | Date: 2018-08-16 18:03 | IP: IP Logged
Program settings / Editor 1
Switch off Smart char completion
