You are here: PSPad forum > English discussion forum > Syntax highlighting sensitive to file size
#1 Syntax highlighting sensitive to file size
Posted by: ejfield | Date: 2018-08-16 10:03 | IP: IP Logged
I was editing a group of Verilog source files, and some of the files did not show any syntax highlighting. I eventually worked out that it was the biggest source files that weren't being handled properly. when I reduced the file sizes, the highlighting started to work.
for reference, a typical file was 507kB, and >7600 lines. PSPAD 5.0.0 (277)
#2 Re: Syntax highlighting sensitive to file size
Posted by: Andreas | Date: 2018-08-16 10:21 | IP: IP Logged
Go to "special settings" and increase some values.
HLOnUpToSize=1000000
MultiHLOnUpToSize=1000000
#3 Re: Syntax highlighting sensitive to file size
Posted by: ejfield | Date: 2018-08-22 07:59 | IP: IP Logged
Thanks for this, that fixed it.
