You are here: PSPad forum > English discussion forum > Cursor isn't where you think it is.
Posted by: steveg | Date: 2018-08-15 11:31 | IP: IP Logged
Some setting must have changed as this is a new problem for me...
If I have this line (which as 2 real tabs in front of it)...
<version>0.0.2<version>
... put the cursor before the 2, press delete then press 3, I get...
<version>0.0.2<3ersion>
It's something to do with the tabs because if I take them out, it all works fine.
Is there a setting I have wrong or is there some way to convert tabs to spaces when the file is opened??
Thanks
Posted by: pspad | Date: 2018-08-15 15:41 | IP: IP Logged
What is your PEPad version?
