You are here: PSPad forum > English discussion forum > Re: New keywords for CSS grid
Posted by: Andreas | Date: 2018-08-14 20:24 | IP: IP Logged
Hello Jan, can you please add following keywords to the CSS.DEF? Taken from css-tricks.com
Properties for the Grid Container
grid-template-columns
grid-template-rows
grid-template-areas
grid-template
grid-column-gap
grid-row-gap
grid-gap
justify-items
align-items
place-items
justify-content
align-content
place-content
grid-auto-columns
grid-auto-rows
grid-auto-flow
grid
Properties for the Grid Items
grid-column-start
grid-column-end
grid-row-start
grid-row-end
grid-column
grid-row
grid-area
justify-self
align-self
place-self
Thank you.
Posted by: Andreas | Date: 2018-10-23 12:58 | IP: IP Logged
Hello Jan,
I'm still missing some new modern properties for CSS.
CSS syntax:
SELECTOR {
PROPERTY: VALUE;
/* OR */
@QUERY {
SELECTOR {
PROPERTY: VALUE;
Comment
/* comment */
Extended comment for browser dev tools
/*! comment */
Here is a complete list taken from w3.org www.w3.org
align-content
align-items
align-self
alignment-baseline
all
animation
animation-delay
animation-direction
animation-duration
animation-fill-mode
animation-iteration-count
animation-name
animation-play-state
animation-timing-function
appearance
azimuth
background
background-attachment
background-blend-mode
background-clip
background-color
background-image
background-origin
background-position
background-repeat
background-size
baseline-shift
block-ellipsis
block-overflow
block-size
block-step
block-step-align
block-step-insert
block-step-round
block-step-size
bookmark-label
bookmark-level
bookmark-state
border
border-block
border-block-color
border-block-end
border-block-end-color
border-block-end-style
border-block-end-width
border-block-start
border-block-start-color
border-block-start-style
border-block-start-width
border-block-style
border-block-width
border-bottom
border-bottom-color
border-bottom-left-radius
border-bottom-right-radius
border-bottom-style
border-bottom-width
border-boundary
border-collapse
border-color
border-end-end-radius
border-end-start-radius
border-image
border-image-outset
border-image-repeat
border-image-slice
border-image-source
border-image-width
border-inline
border-inline-color
border-inline-end
border-inline-end-color
border-inline-end-style
border-inline-end-width
border-inline-start
border-inline-start-color
border-inline-start-style
border-inline-start-width
border-inline-style
border-inline-width
border-left
border-left-color
border-left-style
border-left-width
border-radius
border-right
border-right-color
border-right-style
border-right-width
border-spacing
border-start-end-radius
border-start-start-radius
border-style
border-top
border-top-color
border-top-left-radius
border-top-right-radius
border-top-style
border-top-width
border-width
bottom
box-decoration-break
box-shadow
box-sizing
box-snap
break-after
break-before
break-inside
caption-side
caret
caret-color
caret-shape
chains
clear
clip
clip-path
clip-rule
color
color-adjust
color-interpolation-filters
column-count
column-fill
column-gap
column-rule
column-rule-color
column-rule-style
column-rule-width
column-span
column-width
columns
contain
content
continue
counter-increment
counter-reset
counter-set
cue
cue-after
cue-before
cursor
direction
display
dominant-baseline
elevation
empty-cells
fill
fill-break
fill-color
fill-image
fill-opacity
fill-origin
fill-position
fill-repeat
fill-rule
fill-size
filter
flex
flex-basis
flex-direction
flex-flow
flex-grow
flex-shrink
flex-wrap
float
float-defer
float-offset
float-reference
flood-color
flood-opacity
flow
flow-from
flow-into
font
font-family
font-feature-settings
font-kerning
font-language-override
font-max-size
font-min-size
font-optical-sizing
font-palette
font-size
font-size-adjust
font-stretch
font-style
font-synthesis
font-synthesis-small-caps
font-synthesis-style
font-synthesis-weight
font-variant
font-variant-alternates
font-variant-caps
font-variant-east-asian
font-variant-emoji
font-variant-ligatures
font-variant-numeric
font-variant-position
font-variation-settings
font-weight
footnote-display
footnote-policy
gap
glyph-orientation-vertical
grid
grid-area
grid-auto-columns
grid-auto-flow
grid-auto-rows
grid-column
grid-column-end
grid-column-start
grid-row
grid-row-end
grid-row-start
grid-template
grid-template-areas
grid-template-rows
hanging-punctuation
height
hyphenate-character
hyphenate-limit-chars
hyphenate-limit-last
hyphenate-limit-lines
hyphenate-limit-zone
hyphens
image-orientation
image-rendering
image-resolution
initial-letters
initial-letters-align
initial-letters-wrap
inline-size
inline-sizing
inset
inset-after
inset-before
inset-block
inset-block-end
inset-block-start
inset-end
inset-inline
inset-inline-end
inset-inline-start
inset-start
isolation
justify-content
justify-items
justify-self
left
letter-spacing
lighting-color
line-break
line-clamp
line-grid
line-height
line-height-step
line-padding
line-sizing
line-snap
list-style
list-style-image
list-style-position
list-style-type
margin
margin-block
margin-block-end
margin-block-start
margin-bottom
margin-inline
margin-inline-end
margin-inline-start
margin-left
margin-right
margin-top
marker
marker-end
marker-knockout-left
marker-knockout-right
marker-mid
marker-pattern
marker-segment
marker-side
marker-start
mask
mask-border
mask-border-mode
mask-border-outset
mask-border-repeat
mask-border-slice
mask-border-source
mask-border-width
mask-clip
mask-composite
mask-image
mask-mode
mask-origin
mask-position
mask-repeat
mask-size
mask-type
max-block-size
max-height
max-inline-size
max-lines
max-width
min-block-size
min-height
min-inline-size
min-width
mix-blend-mode
nav-down
nav-left
nav-right
nav-up
object-fit
object-position
offset
offset-after
offset-anchor
offset-before
offset-distance
offset-end
offset-path
offset-position
offset-rotate
offset-start
opacity
order
orphans
outline
outline-color
outline-offset
outline-style
outline-width
overflow
overflow-block
overflow-inline
overflow-wrap
overflow-x
overflow-y
padding
padding-block
padding-block-end
padding-block-start
padding-bottom
padding-inline
padding-inline-end
padding-inline-start
padding-left
padding-right
padding-top
page
page-break-after
page-break-before
page-break-inside
pause
pause-after
pause-before
pitch
pitch-range
place-content
place-items
place-self
play-during
position
presentation-level
quotes
region-fragment
resize
rest
rest-after
rest-before
richness
right
row-gap
ruby-align
ruby-merge
ruby-position
running
scroll-behavior
scroll-margin
scroll-margin-block
scroll-margin-block-end
scroll-margin-block-start
scroll-margin-bottom
scroll-margin-inline
scroll-margin-inline-end
scroll-margin-inline-start
scroll-margin-left
scroll-margin-right
scroll-margin-top
scroll-padding
scroll-padding-block
scroll-padding-block-end
scroll-padding-block-start
scroll-padding-bottom
scroll-padding-inline
scroll-padding-inline-end
scroll-padding-inline-start
scroll-padding-left
scroll-padding-right
scroll-padding-top
scroll-snap-align
scroll-snap-stop
scroll-snap-type
scrollbar-color
scrollbar-gutter
scrollbar-width
shape-image-threshold
shape-inside
shape-margin
shape-outside
speak
speak-as
speak-header
speak-numeral
speak-punctuation
speech-rate
stress
string-set
stroke
stroke-align
stroke-alignment
stroke-break
stroke-color
stroke-dash-corner
stroke-dash-justify
stroke-dashadjust
stroke-dasharray
stroke-dashcorner
stroke-dashoffset
stroke-image
stroke-linecap
stroke-linejoin
stroke-miterlimit
stroke-opacity
stroke-origin
stroke-position
stroke-repeat
stroke-size
stroke-width
tab-size
table-layout
text-align
text-align-all
text-align-last
text-combine-upright
text-decoration
text-decoration-color
text-decoration-line
text-decoration-skip
text-decoration-skip-ink
text-decoration-style
text-decoration-width
text-emphasis
text-emphasis-color
text-emphasis-position
text-emphasis-skip
text-emphasis-style
text-group-align
text-indent
text-justify
text-orientation
text-overflow
text-shadow
text-space-collapse
text-space-trim
text-spacing
text-transform
text-underline-offset
text-underline-position
text-wrap
top
transform
transform-box
transform-origin
transition
transition-delay
transition-duration
transition-property
transition-timing-function
unicode-bidi
user-select
vertical-align
visibility
voice-balance
voice-duration
voice-family
voice-pitch
voice-range
voice-rate
voice-stress
voice-volume
volume
white-space
widows
width
will-change
word-break
word-spacing
word-wrap
wrap-after
wrap-before
wrap-flow
wrap-inside
wrap-through
writing-mode
z-index
Edited 2 time(s). Last edit at 2018-10-23 12:59 by Andreas.
Posted by: pspad | Date: 2018-10-23 13:28 | IP: IP Logged
I compare internal CSS highlighter list with your list and added all missing words into CSS highlighter. Next build will contains it.
Posted by: Andreas | Date: 2018-10-23 14:10 | IP: IP Logged
Thank you so much in advance.
