You are here: PSPad forum > English discussion forum > Re: Multiuser environment: clip definitions and language settings
#1 Multiuser environment: clip definitions and language settings
Posted by: stanislav.mikusek | Date: 2018-07-10 12:09 | IP: IP Logged
we have a PSPad on a company server (Windows Server 2008).
PSPad.exe is in the "C:\Program File (x86)\PSPad editor" and we have a multiuser environment set up.
But the only what users have is their PSPad.INI and open files history Recent.INI in C:\Users\[User]\AppData\Roaming\ .
They can't save their clip definitions to Context\[Language].DEF or set individual programming languages in Syntax\[Language].INI.
To overcome this, each user have to have their own PSPad installation in their home directory.
Can I customize clip definitions and language settings in a multiuser environment?
Stanislav Mikušek
#2 Re: Multiuser environment: clip definitions and language settings
Posted by: pspad | Date: 2018-07-10 12:48 | IP: IP Logged
User customizable path system in PSpad is already prepared, but there is no form for it.
I am not sure if this settings should be
1. individual for each user - in this case each can have own folders stored in pspad.ini
2. common for PSpad installation - folders will be in same location for all users
Option 1 is more variable, but brings more complications (management) to IT administrator.
#3 Re: Multiuser environment: clip definitions and language settings
Posted by: stanislav.mikusek | Date: 2018-07-16 15:49 | IP: IP Logged
Both are possible.
