You are here: PSPad forum > English discussion forum > Odd php files appearing with names like U0208976.php
#1 Odd php files appearing with names like U0208976.php
Posted by: jean123456 | Date: 2018-06-10 00:22 | IP: IP Logged
I'm running php in XAMPP so they could be coming from either. They contain php source code. I did change some pspad settings but nothing affecting e.g. backup.
Thanks in advance
j
#2 Re: Odd php files appearing with names like U0208976.php
Posted by: pspad | Date: 2018-06-10 07:52 | IP: IP Logged
hello
If you preview modified file or select part of the file and preview it, PSPad will create temporary file and this file will be send as preview or into external application.
Any external application (your web server or browser) works with existing file on the disk. The solution is save file before any preview, but the automatical file save can be unwanted.
