You are here: PSPad forum > English discussion forum > Program installs in wrong directory
Posted by: Tom-Trottier | Date: 2018-05-24 07:22 | IP: IP Logged
I installed the 5.0.0.277 version using the installer, but it installed in
"C:\Program Files (x86)\PSPad editor"
rather than
"C:\Program Files (x86)\PSPad"
where I had it before.
Oddly the W10 Add or Remove programs updated the version number, but objected to an uninstall of the new version when I had the old version running.
Posted by: pspad | Date: 2018-05-24 09:18 | IP: IP Logged
Target folder is on the second installer screen.
You can uninstall PSPad with the file in the install folder. There should be something like Uninst.exe
I suggest you uninstall the new version and install it into existing folder
