You are here: PSPad forum > English discussion forum > Re: WHO TO Compile....?
Posted by: Gabriel_ACE | Date: 2018-01-24 14:52 | IP: IP Logged
hi!
I created a project.
the project has at last 40 source code in COBOL
how can I compile all the project at once ???
Best Regards
Edited 1 time(s). Last edit at 2018-01-24 14:53 by Gabriel_ACE.
Posted by: pspad | Date: 2018-01-24 15:00 | IP: IP Logged
I don't know Cobol. Is there any main file as in any other language?
Set main project file as main (right mouse)
When you will run compilation, the main file will be send to compiler instead of the current file
Posted by: Gabriel_ACE | Date: 2018-02-21 13:28 | IP: IP Logged
pspad:I don't know Cobol. Is there any main file as in any other language?
each file is compiled separately
if I have this:
a.cob
b.cob
in the project
I need execute 2 times bach command rm85cob.exe
for example
rm85cob.exe c:\a.cob c:\a.cbl
rm85cob.exe c:\b.cob c:\b.cbl
It would be a good addition to the functionality of the project, being able to compile all its components at the same time
I don't wanna do a .BAT file for each proyect
I was thinking of a button that says: "compile all the components"
and for the option to work allow to save within the project
the compiler's command and the extension of the files that must be compiled since a project does not always have only source files, but many times they have documentation files
using wild card for the file OF CORSE
