You are here: PSPad forum > English discussion forum > Re: Multiple search/replace operations within a file
#1 Multiple search/replace operations within a file
Posted by: kwarr | Date: 2016-12-29 16:17 | IP: IP Logged
Is there a way to automate the search/replace function within a file? I have been trying to find a way to do it in vbscript but without success.
I regularly receive files that I have to prepare in HTML, doing the same search and replace process in each file, such as:
Replace <td with <td class="XXX"
Replace <p with <p class="yyyy"
Replace </span> </span> with ""
.. and so on
Since I am making exactly the same changes each time I want to automate the process.
Just to be clear: this is multiple search and replace within a single file. I can, of course, paste the text into Word, run a macro there and then paste it back but I'm sure there is a better way.
I should be very grateful for help with this
Kip
#2 Re: Multiple search/replace operations within a file
Posted by: pspad | Date: 2016-12-29 16:30 | IP: IP Logged
You can use user convertor.
There is a template.in_ in the .\PSPad\Convert folder
Rename it to e.g. My multireplace.ini
Modify Forward and Backward name
Put list of your replace into [conversion] section, e.g.
[conversion]
<td|<td class="XXX"
<p|<p class="yyyy"
</span> </span>|""
Delete whole [Table] section (or let it be). CharTab=0 tells PSPad to don't use Char table but conversion list
When you will be done, you can run your convertor in menu Tools / User convertors
You can assign shortcut to action Run last used convertor to quickly run convertor on more files
