You are here: PSPad forum > English discussion forum > Re: font size of items in Tool Panel
Posted by: zeek5512 | Date: 2016-08-04 13:17 | IP: IP Logged
Is there a way to change the font size of items in the Tool Panel?
I know how to set the font size in the Edit window. I can also change it interactively with my mouse scroll wheel. However the Tool Panel font size of the currently open files for example does not change. I thought in some older version this worked but I might be confusing this with another app.
I have looked in the Direct Edit file and found nothing obvious for this feature. Have I missed it or is this feature missing from PSPad?
Edited 1 time(s). Last edit at 2016-08-04 13:18 by zeek5512.
Posted by: dmittleider | Date: 2016-08-15 19:07 | IP: IP Logged
I'd second that but also in the tabs. In this 4.6.1 version especially at higher DPI's they tabs are hard to read. The interface tries to scale but I almost prefer the fonts looked on the UI in older versions, even if at say 150% or 175% it was blurry.
Posted by: pspad | Date: 2016-08-16 04:56 | IP: IP Logged
I will do it, but be patient please. I was on vacation and tomorrow I will be out to end of the week.
Posted by: dmittleider | Date: 2016-08-17 16:03 | IP: IP Logged
Thanks!
Posted by: Ravelli | Date: 2020-12-14 15:39 | IP: IP Logged
Hi all,
has this already been implemented? Would be nice to get a feedback, since I can not find it.
Friendly greetings,
Ravelli
Posted by: lphilpot01 | Date: 2025-08-05 03:30 | IP: IP Logged
Five years later...
Any possibility of user control over the UI font (size)? As my eyes get older and monitors get higher-res, these small(er) UI fonts get harder to read.
Retired ... finally!
Posted by: Alex | Date: 2025-08-26 02:19 | IP: IP Logged
Really want this to be implemented... I waited for like 10 years. How can I help?
Also, with some magic one some computers I had big font on left menu. But it happend ones a month ago and never happened after.
Posted by: pspad | Date: 2025-08-26 05:14 | IP: IP Logged
If you need bigger system font, change system settings.
Posted by: Alex | Date: 2025-10-09 11:12 | IP: IP Logged
Well. It is still not consistent. And also system zoom or font-size breaks other programs. Ftp size is really small. I'd be very happy to customize it. And also it'd be great to edit columns, like remove unused ones, or save sorting column between sessions.
Posted by: pspad | Date: 2025-10-09 12:38 | IP: IP Logged
I will check font size in the FTP Windows - reason why the font doesn't respect the Window settings
