You are here: PSPad forum > English discussion forum > help ~ how to delete certain item in "Search Files Results" window?
Posted by: xxxljp | Date: 2016-05-27 03:47 | IP: IP Logged
As title, how to delete certain item in "Search Files Results" window?
thank you very much.
Posted by: pspad | Date: 2016-05-27 04:01 | IP: IP Logged
Delete file, containing string you are search for and search again.
There is no possibility to delete results and up to now there was no such request for this functionality.
Explain please the reason and what do you want to do. maybe it will be useful for other users too and I will implement it.
Posted by: xxxljp | Date: 2016-05-27 05:15 | IP: IP Logged
thanks for reply,
when search the keyword in project folder,
you may get a lot of search results,
and i just need part of them.
so, after make sure the result is useless,
i hope can remove(delete) certain result,
not delete file, and keep useful one.
Posted by: pspad | Date: 2016-05-27 08:01 | IP: IP Logged
There is no problem to add possibility add this functionality
Posted by: xxxljp | Date: 2016-05-27 09:25 | IP: IP Logged
Posted by: hhoefling | Date: 2016-05-27 11:25 | IP: IP Logged
Jan,
you can think of it as a Todo-List ... after work it's empty
But i don't need such a function, i repeat the search until List is empty.
by HH
Edited 1 time(s). Last edit at 2016-05-27 11:26 by hhoefling.
