You are here: PSPad forum > English discussion forum > Search/replace line-shifts?
#1 Search/replace line-shifts?
Posted by: rasved | Date: 2016-05-02 08:37 | IP: IP Logged
Hi.
How can I search and replace a line-space?
Original:
abc
def
abc
def
abc
def
abc
def
abc
def
abc
def
abc
def
How can I search replace to get this result:
abcdef
abcdef
abcdef
abcdef
abcdef
abcdef
abcdef
Thanks in advance
#2 Re: Search/replace line-shifts?
Posted by: Andreas | Date: 2016-05-02 11:16 | IP: IP Logged
Multiline search seems not to work with the build in tool. You can use the script "Multiline Search / Replace"
Search:
Replace:
$1$2
Using regex.
