You are here: PSPad forum > English discussion forum > Re: Special chars font
Posted by: DenTNT | Date: 2016-03-25 12:53 | IP: IP Logged
Is there a way to set colors or font size for the special chars like EOL?
Posted by: pspad | Date: 2016-03-25 13:03 | IP: IP Logged
You can set color for white space chars in each highlighter. You can't set font.
Posted by: DenTNT | Date: 2016-03-25 14:34 | IP: IP Logged
pspad:You can set color for white space chars in each highlighter. You can't set font.
Excuse me, but I cannot find this option. Where can I set colors for the space char for the TEXT or default file format?
Edited 1 time(s). Last edit at 2016-03-25 14:35 by DenTNT.
Posted by: pspad | Date: 2016-03-25 15:29 | IP: IP Logged
Settings / Highlighter settings / Space (colors tab for each highlighter attribute)
Edited 1 time(s). Last edit at 2016-03-25 15:30 by pspad.
Posted by: DenTNT | Date: 2016-03-25 15:47 | IP: IP Logged
pspad:Settings / Highlighter settings / Space (colors tab for each highlighter attribute)
Thank you, but how can I change TEXT or *.* file color scheme?
Posted by: pspad | Date: 2016-03-25 16:02 | IP: IP Logged
Text or file without highlighter file has no attributes and possibility to change it.
You can create new user highlighter and fill *.txt as file mask only. Then you will be able to set up space attribute.
