You are here: PSPad forum > English discussion forum > PSPAD for MAC
Posted by: pythonui | Date: 2016-02-29 03:30 | IP: IP Logged
Hello Jan,
I have been using "PSPAD" in windows system since many years. It is good editor for me. I have written many scripts for my daily usage. I am using "PSPAD" for everything (Reading, Coding etc). Now I have new laptop(Macbook pro). So my basic question is how can I use PSPAD in MAC ? Yes using "WINE" I am able to use in MAC, But what can I do for my scripting? Please guide me for this ? How can I do scripting in PSPAD for MAC?
(Is it possible to port PSPAD for MAC ?)
Thanks
Posted by: pspad | Date: 2016-02-29 11:50 | IP: IP Logged
I am sorry, I have no experiences with MAC and wine.
Try to look at some advices here and install WSH into wine:
bit.ly
Edited 1 time(s). Last edit at 2016-02-29 11:50 by pspad.
Posted by: pythonui | Date: 2016-03-01 07:39 | IP: IP Logged
Thank you for reference ! Not useful in my case... Not able to install wsh on mac. Need to find some workaround for this.
Thanks
Posted by: gwinkless | Date: 2016-03-01 12:22 | IP: IP Logged
pythonui:Thank you for reference ! Not useful in my case... Not able to install wsh on mac. Need to find some workaround for this.
Not able because?
What error do you get? Is it just that the winetricks file doesn't run? It looks like it's designed for Linux only...
Looking through the winetricks script it looks like (for jscript) you must download
and then run
rm $WINEPREFIX/dosdevices/c:/windows/system32/jscript.dll
wine Windows2000-KB917344-56-x86-enu.exe /q
then for vbscript download download.microsoft.com and run
rm $WINEPREFIX/dosdevices/c:/windows/system32/vbscript.dll
wine vbs56men.exe /q
If WINEPREFIX isn't set then you should probably replace it with $HOME/.wine
HTH
Edited 1 time(s). Last edit at 2016-03-01 12:24 by gwinkless.
Posted by: pythonui | Date: 2016-03-02 03:18 | IP: IP Logged
@gwinkless Thank You very much for your answer !
I have found another workaround for this.. I have downloaded winebottler.kronenberg.org and then install PSPAD using that. This has inbuilt support of winetricks and now I am able to install wsh for jscript,vbscript and csscript.
Thanks
Posted by: pythonui | Date: 2016-03-02 03:27 | IP: IP Logged
Hello Jan,
I have installed PSPAD on mac, but I found theme of this is different then what I am using in Windows 8. See this
Is there any setting to do for this?
