You are here: PSPad forum > English discussion forum > Possible to hide File Extension in opened documents\tabs
Posted by: 2muchacid | Date: 2016-02-28 16:52 | IP: IP Logged
hi
working with many files at once gets the tab view quiet big. All the files display the .txt extension, so is it possible to hide the extension from tabs to make them shorter?
thanks!!
Posted by: pspad | Date: 2016-02-28 18:00 | IP: IP Logged
Just now it isn't possible. You can modify file TAB content in the program settings / Program 2.
Default format is %n%.. %name%
Change it to %name%
You can shorten file name adding %d:50 to 50 pixeks (modify it as you need)
But there isn't problem to add e.g. %file% and %ext% in the future and you will be able to display file name without extension.
Another possibility - on the left panel you can show file list, hide file tabs and navigate using left panel only.
Edited 1 time(s). Last edit at 2016-02-28 18:03 by pspad.
Posted by: 2muchacid | Date: 2016-03-01 08:37 | IP: IP Logged
Thanks for the reply!
I changed to %name% and it helped.
Didn't understand the "You can shorten file name adding %d:50 to 50 pixeks (modify it as you need)" part, where is that setting?
Kind regards
Posted by: pspad | Date: 2016-03-01 08:48 | IP: IP Logged
Input it after %name% in program settings. Hint over edit will tell you format. So the result will look like:
%name% %d:50
50 means 50 pixels. Change to value to fit it best for you
Edited 1 time(s). Last edit at 2016-03-01 08:49 by pspad.
Posted by: pspad | Date: 2016-03-08 10:02 | IP: IP Logged
I am very sorry, I forgot parameter.
On the Program settings / Program 1 is parameter []File tabs - don't show file extension
This is functionality you requested
Posted by: 2muchacid | Date: 2016-03-13 08:19 | IP: IP Logged
Thanks for your help!
