You are here: PSPad forum > English discussion forum > [REQUEST] - Synchronized scrolling on splitted windows
Goto Page: Previous1 2
#11 Re: [REQUEST] - Synchronized scrolling on splitted windows
Posted by: gwinkless | Date: 2020-08-27 08:54 | IP: IP Logged
It shouldn't be so big problem.
That's all I ask. I'm hoping it's just a UI change because "synchonize moving" context menu option is disabled for the current tab (so enabling it when the tab is split would be a small change); if it's a big job because the control doesn't support synchronized split natively, then that's a different thing - I need this maybe once every few months so I wouldn't want you to spend hours on it.
Cheers
#12 Re: [REQUEST] - Synchronized scrolling on splitted windows
Posted by: pspad | Date: 2020-09-10 10:39 | IP: IP Logged
Synchronization in splitted window will be available from next build
#13 Re: [REQUEST] - Synchronized scrolling on splitted windows
Posted by: gwinkless | Date: 2020-09-11 09:13 | IP: IP Logged
Just tried it out, it works perfectly, thanks!!
