You are here: PSPad forum > English discussion forum > Scripting : Text Diff
Posted by: pythonui | Date: 2015-11-03 05:55 | IP: IP Logged
Is this possible to call 'Text Diff with this file' from script ?
Thanks
Posted by: pspad | Date: 2015-11-03 06:23 | IP: IP Logged
Run PSPad action aDiffFile using
runPSPadAction(ActionName: string)
I know, the action isn't listed in the scripting.txt or help.
To see all actions go to program settings / KeyMap and press Direct edit button
Posted by: pythonui | Date: 2015-11-03 06:57 | IP: IP Logged
Thanks for answer
Posted by: pythonui | Date: 2015-11-06 06:15 | IP: IP Logged
Is there any function that takes the input as two file names and return with the 'Text difference' ? (Really useful function for automate text difference)
Thanks
Edited 1 time(s). Last edit at 2015-11-06 06:15 by pythonui.
Posted by: pspad | Date: 2015-11-06 06:36 | IP: IP Logged
What is the usage? Can you give me any example?
Posted by: pythonui | Date: 2015-11-06 06:43 | IP: IP Logged
I have been using 'Git' for version control. I need to see the difference of last version file and current version file so firstly my script take the last version file from 'Git' and save it in current directory. So after this I need to use 'Text Diff' functionality of PSPAD to see the difference between these two files.
Thanks
Edited 1 time(s). Last edit at 2015-11-06 06:45 by pythonui.
Posted by: pythonui | Date: 2015-11-06 08:40 | IP: IP Logged
Actually I don't want to integrate any other diff tool in PSPAD because we have good diff tool in PSPAD.
Posted by: pspad | Date: 2015-11-06 08:57 | IP: IP Logged
I will add scripting support.
I don't know how I will realize it yet. There are 2 ways:
1. function with 2 editor objects as parameters
2. function with 2 filenames as parameters
Posted by: pythonui | Date: 2015-11-06 09:27 | IP: IP Logged
Yes...thanks
I think first would be the great !
Thanks
Posted by: pythonui | Date: 2015-11-06 10:53 | IP: IP Logged
I think second one also important as first one ! (Thought)
