You are here: PSPad forum > English discussion forum > Underscore characters in SQL syntax
Posted by: Freeman | Date: 2015-10-30 09:27 | IP: IP Logged
How can I add underscore character '_' as identifier character for SQL syntax? When I moving through the text via Ctrl+Left/Right, cursor stops on every underscore in identifiers, what's not right.
AFAIK, SQL syntax highlighter is built-in PSPad, I cannot find a setting for it. If it isn't user-controllable, Jan, please add underscore to SQL in next build of PSPad.
Posted by: pspad | Date: 2015-10-30 10:26 | IP: IP Logged
I will modify it.
