You are here: PSPad forum > English discussion forum > Re: File Tab Name
Posted by: pythonui | Date: 2015-09-23 07:27 | IP: IP Logged
Why file tab name variable(File Tab caption format) 'n' is only increment upto 10 ?
| 1 test.py | 2 test1.py |
Like this 1,2...
Thanks
Posted by: pspad | Date: 2015-09-23 08:05 | IP: IP Logged
Cause first 10 tabs are available with quick access as Alt+num
You can remove numbering from tab in program settings / Program 1
There is a Tab format string
Posted by: pythonui | Date: 2015-09-23 08:22 | IP: IP Logged
Ohh ! Got it..
Thanks
Posted by: pythonui | Date: 2015-09-25 06:47 | IP: IP Logged
Just suggestion !
Is there any possibility to have close button on File Tab ? (Like other editors)
Thanks
Posted by: pspad | Date: 2015-09-25 09:31 | IP: IP Logged
Close button extends File tab width.
You can close file tab with middle mouse button, Shift+Click, DblClick
Is't more comfotable than point to small cross on the tab.
Posted by: pythonui | Date: 2015-09-25 09:41 | IP: IP Logged
Ohh ! That's great
