You are here: PSPad forum > English discussion forum > Re: How to force pspad to open a file with encoding UTF-8
Posted by: torro | Date: 2015-09-09 14:43 | IP: IP Logged
I have a bench of files and I want that pspad all files open with encoding UTF-8 no matter which encoding the files are.
I tried to set "Format" to UTF-8 doesn't help
I tried to set "Settings" "Program Setting" "Files and dir" "Default CP for files opening" to UTF-8
still opens files as ANSI.
Is it possible to force pspad to open the files in UTF-8?
Thanks a lot,
Torro
Posted by: pspad | Date: 2015-09-09 15:18 | IP: IP Logged
There is several reasons, why PSPad opens files as ANSI instead of UTF-8
1. there is no BOM and your UTF-8 doesn't contains any accented chars. In this case content of ANSI and UTF-8 is same - there are no chars encoded in UTF-8
2. file is encoded in UTF-8 but there are some errors (e.g. file contains non encoded chars). Typically exports from MySQL. In case you open this file as UTF-8, you will lost some chars.
To force PSPad open file as UTF-8:
open your file
in the format menu click to UTF-8 (click it even UTF-8 is selected)
Use reload file (Ctrl+R)
Posted by: torro | Date: 2015-09-09 15:34 | IP: IP Logged
Thanks a lot.
Yes, there is not a BOM. The files are php files.
And yes the files are coded in UTF-8, but have one or two signs which are not UTF-8 signs.
Unfortunately your procedure doesn't work (I followed the procedure carefully). The files still encoded wrong.
Posted by: pspad | Date: 2015-09-09 15:56 | IP: IP Logged
What PSpad version do you use? Can you test latest buld from PSPad developer forum?
Can you send me to support mail any of your file?
Posted by: torro | Date: 2015-09-09 16:15 | IP: IP Logged
Thanks a lot.
I used the 4.5.9. build 2600
now I tried build 2669 and it worked. So it is already solved.
Thanks a lot
