You are here: PSPad forum > English discussion forum > Add/Remove Comment not working
Goto Page: Previous1 2
#11 Re: Add/Remove Comment not working
Posted by: johnbentley | Date: 2021-05-22 05:13 | IP: IP Logged
`Add/Remove Comment` is not working for me on version 5.0.6 (589), 32 bit.
Settings > Program Settings > System Integration > Integrated scripting support WSH: ticked.
I have "Comments" under the "Scripts" menu. They work if chosen via the menu.
Highlighting a line in a .css file or a .xhtml file > Format > Add/Remove Comment. ... does nothing.
Any suggestions?
#12 Re: Add/Remove Comment not working
Posted by: pspad | Date: 2021-05-22 06:09 | IP: IP Logged
Items out of the Script menu don't depend of the scripting
Add / Remove comment works for line comments, not for multiline comments.
CSS doesn't support line comments
You can use Code clips to comment your line
Select line/lines in your CSS
Press Ctrl+Space
Select comment and confirm
You can modify clip file and assign shortcuts for this clip
