You are here: PSPad forum > English discussion forum > How to open more instances..
Posted by: silviogne | Date: 2015-08-28 08:15 | IP: IP Logged
Is it possible to open more files in more instances?
I usually use a link on desktop with -N after the destination address, but I want to open more psPad on double click on different files.
Thx
PS: sorry for my english
Posted by: pspad | Date: 2015-08-28 08:40 | IP: IP Logged
Program settings / Systém integration
uncheck option Only one programm instance
Posted by: silviogne | Date: 2015-08-28 10:49 | IP: IP Logged
I tried but whenever I uncheck the option and save, close and open the program, the option is checked again. Why?
Posted by: silviogne | Date: 2015-08-28 10:52 | IP: IP Logged
Ok, I have to execute the program in Administrator ;)
Thx a lot!
Posted by: pspad | Date: 2015-08-28 12:58 | IP: IP Logged
The option has box before with explanation on the bottom of the form.
Some options (in the fact 2) are common and are stored in program folders.
Cause you have PSpad installed in Program settings, there is necessary to run it as administrator to save this option
Posted by: RobertA | Date: 2016-07-04 18:21 | IP: IP Logged
pspad:The option has box before with explanation on the bottom of the form.
That should probably be noted somewhere. Would have saved me some headaches.
The note only notes that the option is saved in the PSPad folder which could easily be the application data folder.
Robert
Posted by: pspad | Date: 2016-07-04 18:56 | IP: IP Logged
But it's a noted in the program settings form.
Posted by: RobertA | Date: 2016-07-04 20:13 | IP: IP Logged
All the Program Settings form says is that it performs a write to the PSPad folder. I assumed the Program Data folder not the Program Executable Folder.
And regardless, it's then a leap to determine you need administrative privileges if you are not doing windows programming.
Robert
Posted by: pspad | Date: 2016-07-05 05:45 | IP: IP Logged
Hello Robert, please don't be childish.
Please look at this picture:
Can you notice legend in the bottom left and options marked by square?
