You are here: PSPad forum > English discussion forum > Re: windows 10 and CTRL-TAB
Posted by: lorife | Date: 2015-08-11 10:58 | IP: IP Logged
I ofter use CTRL-TAB to switch between TABS in PSPAD.
Since Windows 10, there's a "flicker" when switching, which wasn't there with Windows 7.
Is it something you can fix?
Thank you!
Posted by: pspad | Date: 2015-08-11 17:30 | IP: IP Logged
Your PSPad version? Can you test latest developer build from Developer forum section?
Posted by: carbonize | Date: 2015-08-11 22:28 | IP: IP Logged
I just tested using 4.6.0(2655) and there is a slight flicker where the editor you switch to is momentarily smaller than the viewing port but it quickly resizes itself. Not an issue I would say but possibly their flickering is something worse than mine.
Carbonize
