You are here: PSPad forum > English discussion forum > Re: Unicode Converter
Posted by: MickeyMiner | Date: 2015-06-25 20:12 | IP: IP Logged
I Would like to make a "secret" Encoder/Decoder for my daughter.
It should replace alphanumerical characters with Unicode "pictures".
Any text I try to convert looks like this: "í ¼í¾‰í"
In what encoding do I save the converter correctly?
In what encoding does the original text have to be?
Thanx,
mm
This is my Convert, however it does not work:
[Description]
ForwardName=Veronika Secret Encode
BackwardName=Veronika Secret Decode
ForwardIgnoreCase=1
BackWardIgnoreCase=1
CharTab=0
UTF8List=1
[Conversion]
A|☺
B|⚒
C|
Edited 1 time(s). Last edit at 2015-06-25 20:12 by MickeyMiner.
Posted by: pspad | Date: 2015-06-25 20:56 | IP: IP Logged
Save convertor into UTF-8 encoding.
Open convertor, go to menu format and click on UTF-8
Save it
Posted by: MickeyMiner | Date: 2015-06-25 21:00 | IP: IP Logged
Thanx for a quick response,
I did as you said. When I convert the text, looks like this: "í ¼í¾‰í ¼í¼âšâ˜¼â™«â˜¼â˜â˜¼â›„♫ âšâ˜¼â˜ºâ™¡í ¼í¼âœ‚ â˜ºâ˜‚í ¼í¼ âœ‚"
Cheers,
mm
Posted by: MickeyMiner | Date: 2015-06-26 19:46 | IP: IP Logged
Maybe someone could take the file sniplet from above, create and test the converter and the place it on-line afterwards when it works (send it to me via PM, or add it to next PSPad distribution)
Would be simply great.
mm
Edited 1 time(s). Last edit at 2015-06-26 19:47 by MickeyMiner.
Posted by: vbr | Date: 2015-06-27 15:22 | IP: IP Logged
the following converter code seems to be working for me (saved as utf-8 encoded ini file in \PSPad\Convert\
I suspect, there might be a problem in handling unicode characters outside of the basic range up to 0xFFFF;
such as the used one:
