You are here: PSPad forum > English discussion forum > Re: strange error messge when PSPad starts
Posted by: idefix2 | Date: 2015-06-16 08:52 | IP: IP Logged
First, thank you for this really great editor!
Since a week or so, everytime I load a file into PSPad from the browser context menu, I get an error message box showing:
Fehler
Line: 0 Pos: 0
Description:
OK
I just have to click it away, then everything works normally, but maybe there is an easy way to get rid of that error message.
The error message only comes when opening a file from the browser context menu, it is not displayed when I open the file from the PSPad file menu.
Edited 2 time(s). Last edit at 2015-06-16 08:54 by idefix2.
Posted by: pspad | Date: 2015-06-16 10:39 | IP: IP Logged
Check subfolders in the .\Script folder
I guess there is some empty file of file what isn't script.
If you don't use PSPad scripting, go to program settings / System integration and disable scripting support
Posted by: Andreas | Date: 2015-06-16 11:13 | IP: IP Logged
I also had this one. Try to remove ReadMe.rtf from Script folder.
Posted by: pspad | Date: 2015-06-16 11:50 | IP: IP Logged
Scripts ROOT (.\Scripts) has no influence up to now.
Is there any common thing like a operating system version?
Posted by: Andreas | Date: 2015-06-16 19:28 | IP: IP Logged
Windows 7
Maybe sounds strange, but if I remove the ReadMe.rtf back to Script I get this message again when I try to compile the scripts.
Maybe because I once opened this file and it has another code page than my pspad setting (utf8).
Also once I had this, that when I tried to change a clip file I saw strange chars in it e.g. § was a bad char. When I now save this file it will not work anymore.
Edited 2 time(s). Last edit at 2015-06-16 19:30 by Andreas.
Posted by: pspad | Date: 2015-06-16 19:45 | IP: IP Logged
I will move readme.rtf out of the .\script folder into PSPad root folder with name scripting.rtf
Posted by: idefix2 | Date: 2015-06-16 21:36 | IP: IP Logged
Thank you - removing the readme file helped.
