You are here: PSPad forum > English discussion forum > Re: Refresh Code Explorer
Posted by: antonyh | Date: 2015-05-15 13:16 | IP: IP Logged
Something I find annoying and not sure if there is a workaround, but if you click Refresh on the code explorer and part of the document structure has changed then rather than refreshing the Object part of the code (if you are currently viewing that) it takes you back to the Variables part of the explorer. Has anyone else experienced this? (I'm using PHP).
Posted by: pspad | Date: 2015-05-15 16:32 | IP: IP Logged
What PSPad version do you use?
Posted by: antonyh | Date: 2015-05-21 10:30 | IP: IP Logged
I use 4.5.7
Posted by: pspad | Date: 2015-05-21 11:00 | IP: IP Logged
In the 4.5.9 was implemented "state keep" in Code explorere after refresh. All nodes stays as they are (expanded/collapsed) include selected node. Update.
