You are here: PSPad forum > English discussion forum > current tab visual
Posted by: pspad | Date: 2015-06-16 05:55 | IP: IP Logged
brolx:I don't see any difference in version 2665.
Is it already implemented?
I am sorry. It's implemented, but you have to switch it on.
Open program settings and press direct edit button
Change value of the HighlightCurrentFileTab option to 1:
HighlightCurrentFileTab=1
Current file tab will be highlighted
Posted by: brolx | Date: 2015-06-16 09:34 | IP: IP Logged
What about the name in bold?
Or a custom color if you prefer
Posted by: bwhawk | Date: 2015-06-16 10:44 | IP: IP Logged
I also use Windows without a theme, and I like the highlighted tab in 2661. The ability to change the tab color would be nice, but it's pretty visible as-is.
I wouldn't want the tab to be bold (unless that was an option that could be turned off).
Posted by: pspad | Date: 2015-06-16 10:47 | IP: IP Logged
Bold font means change width of the TAB and continuous recalculating of the tabs when you cycle tabs.
Posted by: brolx | Date: 2015-06-16 13:40 | IP: IP Logged
and what about having the borders of the tab in color (red?)
Posted by: bwhawk | Date: 2015-08-12 15:49 | IP: IP Logged
I'm using HighlightCurrentFileTab=1, and the color of the current tab appears to have changed in 2667. Previously, it was white, but now it's dark grey. With black text, that makes it a bit hard to read.
Is the color being set via another setting that I could change?
Thanks!
Posted by: pspad | Date: 2015-08-12 16:29 | IP: IP Logged
Do you have really black text? It should be darkgray with white text.
Did you set some own color scheme?
Posted by: bwhawk | Date: 2015-08-12 16:49 | IP: IP Logged
Yes, the font color is just black (RGB 000). I'm using the Windows 7 Basic Theme.
Posted by: bwhawk | Date: 2015-08-17 09:28 | IP: IP Logged
In 2669, the current tab is now white text on a dark grey background. Much better! Thank you!
