You are here: PSPad forum > English discussion forum > Selection to PHP variable
#1 Selection to PHP variable
Posted by: carbonize | Date: 2014-11-25 11:57 | IP: IP Logged
The selection to PHP variable function is a bit strange. For a start I would of expected it to put '; at the end. Also after you provide the variable name it puts
$VARIABLENAME ='SELECTED TEXT
with a space before the = but not after.
Carbonize
#2 Re: Selection to PHP variable
Posted by: pspad | Date: 2014-11-25 12:48 | IP: IP Logged
I am sorry, but I don't understand
#3 Re: Selection to PHP variable
Posted by: carbonize | Date: 2014-11-25 14:09 | IP: IP Logged
HTML -> Conversion -> Selection to PHP variable
Carbonize
#4 Re: Selection to PHP variable
Posted by: pspad | Date: 2014-11-25 14:40 | IP: IP Logged
I see.
Now the (strange) result is: $VARIABLENAME ='SELECTED TEXT
The correct result should be: $VARIABLENAME = 'SELECTED TEXT';
or
$VARIABLENAME='SELECTED TEXT';
Do you prefer spaces before equal sign or not? I don't know customs in PHP
#5 Re: Selection to PHP variable
Posted by: pspad | Date: 2014-11-25 14:51 | IP: IP Logged
The space before '=' was due to multiline conversion
$test ='something'."\n";
$test.='something else';
#6 Re: Selection to PHP variable
Posted by: carbonize | Date: 2014-11-25 20:55 | IP: IP Logged
Not that I will probably use this function but the usual method is a space either side of the =
Carbonize
