You are here: PSPad forum > English discussion forum > Re: Auto comment
Posted by: carbonize | Date: 2014-10-19 16:44 | IP: IP Logged
In PHP when writing a comment using
PSPad automatically adds the * after the second line when you press enter but for some reason it puts how ever many spaces it is indented after the * as well
I will use ~ to represent a space
Hope that makes sense.
Carbonize
Posted by: Andreas | Date: 2014-10-20 05:18 | IP: IP Logged
Yes, this is a correct document block for php comments.
~*~Comment goes here
i.e. phpdoc.org /docs/latest/glossary.html
Posted by: pspad | Date: 2014-10-21 10:37 | IP: IP Logged
Fixed.
There was a problem - PSPad should respect spaces behind the asterisk upt to first non space char. Correct behavior is this one:
~~~~~~*~~some text starts here
It means you can continue your comment aligned as previous line.
Posted by: Andreas | Date: 2014-10-21 12:26 | IP: IP Logged
Ah, this is great, up to now I always hade to type in an extra space on newline.
Posted by: froschi | Date: 2019-09-18 12:46 | IP: IP Logged
where can i change this behavior?
in current build, when pressing return the blank after * is missing.
Posted by: pspad | Date: 2019-09-18 15:18 | IP: IP Logged
There is no setting to change it.
Current behavior: the first line is without space, but if you will write anything behind the * char, next line will copy all spaces or tabs from the previous line.
I can make little modification - the first line will contains space behind the '*'
