You are here: PSPad forum > English discussion forum > Log window size issue with laptop and external monitor switching
#1 Log window size issue with laptop and external monitor switching
Posted by: sankyo | Date: 2013-05-30 21:36 | IP: IP Logged
I use the latest version of PSPad on my laptop with external (bigger) monitor.
Following use case:
I open PSPad on this monitor, I open the log window and resize it in order to see more details. I close PSPad, undock laptop (disconnect the monitor) and start PSPad on the laptop screen. Now sometimes the log window is so big that I cannot resize it. I cannot even scroll to the most upper point in order to export the content of this window.
The problem persists until I dock the laptop again and resize the log window again on the monitor.
I've seen this issue in several versions till now, so it is not version dependent. I had this issue with Windows XP and now with Windows 7.
Any idea how can I fix it?
And no, I cannot alway think about resizing the log window before undocking smiling smiley
Regards and thanks
#2 Re: Log window size issue with laptop and external monitor switching
Posted by: JeanDanielGasser | Date: 2018-10-18 07:01 | IP: IP Logged
I have exactly the same problem, did you found a solution?
Thank you in advance for your answer
Greetings
J-D Gasser
#3 Re: Log window size issue with laptop and external monitor switching
Posted by: JeanDanielGasser | Date: 2018-10-18 07:09 | IP: IP Logged
I found the solution !
Edit PSPad.INI file located in "%AppData%\PSpad" folder with NotePad (don't use PSPad editor to edit the settings)
Find "LogHeight=" and replace the value by "200" for example.
Save the file
Start PSPad and log should be completely visible.
#4 Re: Log window size issue with laptop and external monitor switching
Posted by: pspad | Date: 2018-10-18 07:52 | IP: IP Logged
What PSPad version do you use?
There is button on the right top corner of log window to fast set big/small log size
