You are here: PSPad forum > English discussion forum > Re: How to hide the left, grey gutter column and the vertical line (print border?)?
Posted by: pstein | Date: 2013-05-06 14:36 | IP: IP Logged
When I currently open a new file in PsPad then on the left side there is a grey
column/gutter.
How can I disable it?
Furthermore I want to hide the vertical line which appears soemwhere in the mid of the page.
I guess it is the indicator for the print page dimension.
Peter
Posted by: pspad | Date: 2013-05-06 15:50 | IP: IP Logged
Left gutter: program settings / Editor 1 - autohide left gutter. But there is some bug, cause it doesn't work
Right margin: program settings / Editor 2 - set position e.g. to 1000. Left gutter is used for paragraph formating e.t.c.
Posted by: LukasKriz | Date: 2020-07-24 09:09 | IP: IP Logged
On older versions was possible to move the right side line by clicking the left mouse button to the top ruler. But that is not possible on the version 5.0.3.
Posted by: referencement-montpellier | Date: 2020-07-28 15:58 | IP: IP Logged
Are you sur ?
Posted by: pspad | Date: 2020-07-28 16:54 | IP: IP Logged
It is still possible. You need to click in editor first. There is a problem (bugl the click to move right margin isn't available right after open file in editor
