You are here: PSPad forum > English discussion forum > Re: FTP file list window is blank?
Posted by: Chargin | Date: 2012-10-09 01:23 | IP: IP Logged
Whenever I connect to any domains on my VPS today, the FTP window that shows all the files and folders on the server is blank..?
I cant see any settings that would have turned that off, its connection I can see the ftp connection log and it all seems ok.
Any ideas? Im using the latest Pspad version.
Posted by: pspad | Date: 2012-10-09 04:10 | IP: IP Logged
Each FTP server has own file list format.
Go to FTP connection settings and uncheck hidden files
Look into FTO log (Ctrl+L) and check if there is no "bad command"
If it doesn't help and you are using PSPad 4.5.7, in The FTP log window press list button and send me result in TXT as attachment.
Posted by: Chargin | Date: 2012-10-09 04:38 | IP: IP Logged
Well I looked at the ftp settings and the hidden files thing didnt work. But I unticked passive mode and now I can see the directories etc. Funny thing is I didnt change this for any of the domains on my server in PSPAD and they all has this same problem..
