You are here: PSPad forum > English discussion forum > Re: Apostrophes and speechmarks
Posted by: carbonize | Date: 2012-09-24 17:28 | IP: IP Logged
Works fine for me copying from Libre Office to PSPad.
Carbonize
Posted by: Silver007A | Date: 2012-09-24 21:26 | IP: IP Logged
Can you try pasting this sentence then. It is straight from my Word page and like in the examples I gave in a previous post the appostrophes are different. Will be interesting to see if they paste into your pspad OK.
I do believe you that it works for you, but I could send screenshots as well
isn’t "are" isn't isn't
‘’’ "" """a few more too. Thanks
Posted by: hhoefling | Date: 2012-09-24 22:04 | IP: IP Logged
Which Font is used to show the Text in PsPad (CodePage?/ unicode?)
Which Charset is used for the File (ansi/Unicode/utf8 OEM)
(look at statusbar of pspad Edit-Window)
by HH
Posted by: Silver007A | Date: 2012-09-25 19:21 | IP: IP Logged
DOS - Ansi (Windows)- Courier New -
Thanks
Posted by: vbr | Date: 2012-09-25 19:54 | IP: IP Logged
Silver007A:DOS - Ansi (Windows)- Courier New -Thanks
Are the "round" apostrophes and quotation marks really lost immediately just on copying them from a word document?
Or is it rather on saving and reopening the file?
- the second case would be understandable, as such characters are outside of the character set supported by windows-1252.
Using, say, utf-8, you would be able to encode any valid unicode character looselessly.
hth,
Posted by: Silver007A | Date: 2012-09-26 08:52 | IP: IP Logged
I've tried a few different ways and even copying to Notepad and then to PSPad. When I check the html in a browser I get this-
I�ve �Speech�
In the PSPas brwoser it shows little squares instead of the symbols above.
I have to edit each and every apostrophe and speechmark to correct it.
Thanks
Posted by: Silver007A | Date: 2012-09-28 10:37 | IP: IP Logged
Posted by: pspad | Date: 2012-09-28 10:40 | IP: IP Logged
Are you sure you have correct META tag charset in your HTML conrresponding to code page what the file is stored?
Posted by: Silver007A | Date: 2012-09-30 10:25 | IP: IP Logged
Looks like that was it. I was rehashing a template I bought off fiverr I think it was. Thanks a lot.
Posted by: Silver007A | Date: 2012-09-30 10:30 | IP: IP Logged
Donated too
