You are here: PSPad forum > English discussion forum > Re: Opening Project files with correct colour formatting ?
Posted by: bob_a_builder | Date: 2012-09-19 15:27 | IP: IP Logged
I'm new to PSpad, looking to edit my existing classic ASP projects, but having trouble opening files up from the project window so that they open up with the correct colour highlighting.
Colour highlighting is set up and working and will display correctly - but only if I click on the 'text' entry on the status bar and change that to be 'ms vb script'
.ASP is a registered file type in PSpad, and Windows is set to open PSpad when clicking on .ASP files
How can i set PSpad so that when clicking on a .asp file in the project window, it opens up showing the MS VB script colour formatting in PsPad editing window ?
Thanks in advance
Bob
Posted by: myf | Date: 2012-09-19 15:41 | IP: IP Logged
I suppose
Settings > Highliters Settings > (Ms VB Script) > File Masks
add "*.asp"
Posted by: bob_a_builder | Date: 2012-09-19 15:49 | IP: IP Logged
Ah,Ha - you suppose correctly !
Thanks, I'm off and running now ....
