You are here: PSPad forum > English discussion forum > Re: Auto Text Indent + Trim Trailing Spaces Bug
Posted by: salianifo | Date: 2012-08-23 20:40 | IP: IP Logged
I've noticed that in the latest version if you have both these options enabled (Auto Text Indent + Trim Trailing Spaces), when you hit backspace after inserting a new line with an indent, instead of backspacing one indent, it removes all the spaces on the line. Eg. (- = space)
<html>
--<head>
----<title>
------Hello
----</title>
--</head>
</html>
After typing "Hello" and hitting enter I get a new line with 6 spaces (3 indents -- indent width 2). If I hit backspace, in previous versions I would have 4 spaces left on the line. In version 4.5.6, it removes all the spaces on the line. The version I was using previously was 4.5.4.
Edited 1 time(s). Last edit at 2012-08-23 20:41 by salianifo.
Posted by: pspad | Date: 2012-08-24 04:23 | IP: IP Logged
Check if there is no check in program settings:
Editor 1 - Trim trailing spaces
Editor 1 - Extended Home key
Posted by: salianifo | Date: 2012-08-24 13:06 | IP: IP Logged
Both options are checked. The issue I have is that with the same options in the different versions handle them differently.
