You are here: PSPad forum > English discussion forum > Re: Cut line
Posted by: shoma | Date: 2012-08-13 09:00 | IP: IP Logged
I would like to know if there is on pspad a link for cutting a line?
I saw a copy line, but I didn't find cut line...
Posted by: pspad | Date: 2012-08-13 14:28 | IP: IP Logged
Delete line - Ctrl+Y is standard many years in Windows world
Press F1 in editor window to see all shortcuts
Posted by: shoma | Date: 2012-08-21 20:22 | IP: IP Logged
thank you for your answer, but I want to paste it after. Is there a way to do that? (copy or cu or both :p)
Posted by: myf | Date: 2012-08-21 20:36 | IP: IP Logged
Not exactly the answer, but you might appreciateSettings > Editor (part 1) > [ ] Extended Cut and Copy
. Its description (tooltip title) says "If text isn't selected, functions Cut and Copy works with actual line."
Posted by: pspad | Date: 2012-08-22 05:47 | IP: IP Logged
shoma:thank you for your answer, but I want to paste it after. Is there a way to do that? (copy or cu or both :p)
In this case standard shortcut is Ctrl+X (Ctrl+V for paste)
Or Shift+Delete (Shift+Insert for paste)
Posted by: shoma | Date: 2012-08-22 06:54 | IP: IP Logged
myf:Not exactly the answer, but you might appreciateSettings > Editor (part 1) > [ ] Extended Cut and Copy
That's it, it's working, thanks you!
pspad:In this case standard shortcut is Ctrl+X (Ctrl+V for paste)
Wasn't working for me, but with the extend it's perfect. Thanks for your help
Edited 1 time(s). Last edit at 2012-08-22 06:56 by shoma.
