You are here: PSPad forum > English discussion forum > Suggestion: File search results open remote file
Posted by: mgutt | Date: 2012-08-03 14:12 | IP: IP Logged
I often use search & replace in files to find specific code lines. After that they are listed in the bottom box. Now double clicking the results opens the local file and jumps to the correct line.
If I want to save my changes I need to upload it manually by switchting to the right folder and choose "save on ftp".
To avoid that I connect to the FTP source and open the file on the remote location first before clicking the result. After I save the file, it is uploaded automatically to the right position.
No my suggestion:
Double clicking the search result downloads and opens the remote file (or by using right mouse context menu)
regards
