You are here: PSPad forum > English discussion forum > HTML Page Preview - Error
#1 HTML Page Preview - Error
Posted by: crax | Date: 2012-07-11 15:15 | IP: IP Logged
Message from webpage
ERROR: Possible problem with your *.gwt.xml module file.
The compile time user.agent value (ie9) does not match the runtime user.agent value (ie8). Expect more errors.
OK
It looks like PSPad is not compatible with IE9.
PSPad version: 4.5.7. (2447) (same with 4.5.6 (2427))
Windows 7 64bit
Internet Explorer 9
#2 Re: HTML Page Preview - Error
Posted by: carbonize | Date: 2012-07-11 15:35 | IP: IP Logged
Should hope it is given I have been using it with IE9 since IE9 came out. Jan had to actually add a function to write a registry entry to even make it render pages as IE9 as Trident defaults to IE6.
Carbonize
#3 Re: HTML Page Preview - Error
Posted by: pspad | Date: 2012-07-11 16:04 | IP: IP Logged
Program settings / System integration
Check Internal browser in IE9 mode option on the bottom of form.
