You are here: PSPad forum > English discussion forum > File Open - Can't see hidden folders and files
Posted by: nergmlam | Date: 2012-05-31 08:17 | IP: IP Logged
Hi
When I use CTRL+O my default view is without the drive and folders shown in left tab, but your file open dialog gives me an option to enable that.
But when I browse for folders and files, I can't se hidden folders and files, even if I rebooted my computer, logged on as local admin, started explorer.exe and enabled view of hidden folders and files, started pspad.exe, CTRL+O, enabled left tab view of folders and files.
And your file open dialog doens't give me an option to enable view of hidden folders and files.
Work-around: Use explorer.exe, rightclick a hidden file, select PsPad.exe
I needed this option in pspad.exe to open:
C:\Users\<MyUserName>\AppData\Roaming\PSpad\PsPad.ini
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: nergmlam | Date: 2012-05-31 08:23 | IP: IP Logged
Hi
Just found out, that in the left tab with drives and folders, I can't see my extra mapped drives to my fileservers, but I can see then using explorer.exe
In your file open dialog box, I can only see my drive C: and D: using my Computer, and using Network, I can't see my extra mapped drives, as drive H:, K:, M:, but only my UNC paths to our company's 3.500 computers, and our fileservers.
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: nergmlam | Date: 2012-05-31 08:26 | IP: IP Logged
And I also found out, that when using UNC paths, your file open dialog box doesn't give me an option to browse to a "higher" folder, but only to subfolders.
Work-around: Type .. as filename, and press ENTER
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: nergmlam | Date: 2012-06-14 07:59 | IP: IP Logged
Hi Pspad
Any news about this topic?
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: nergmlam | Date: 2012-06-27 10:19 | IP: IP Logged
Hi Pspad
Maybe only a hint about a new Build, that solves this issue, or maybe closing this ticket, because it can't be solved
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: bigelowlqebc | Date: 2012-07-03 09:07 | IP: IP Logged
I can see then using explorer.exe .
Posted by: nergmlam | Date: 2012-07-03 14:10 | IP: IP Logged
bigelowlqebc:I can see then using explorer.exe .
Hi begelowlqebc
Yes, I can also see them using Explorer.exe, but I would also like to see them using PsPad's file open dialog box
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: nergmlam | Date: 2012-08-16 15:13 | IP: IP Logged
Hi Pspad
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: pspad | Date: 2012-08-17 12:36 | IP: IP Logged
I found a reason after long time of play.
When you have disabled to view hidden files and folders, PSPad wont show it for you. If you enable it, you will see it.
I know, it's wrong. I will try to find a way.
It's a little complicated, cause PSpad is written in Delphi 7, and this version doesn't count with new Vista and Windows 7 controls. All must be workarrounded by system hooks.
Posted by: nergmlam | Date: 2012-08-20 10:50 | IP: IP Logged
Hi Pspad
On my Windows 7 32 bit Enterprise computer, I have enabled
[Config]
ShowHiddenFiles=1
and I have enabled show hidden files, folders and drives in Explorer.exe
And I still can't see the hidden files in PsPad
But I'm happy to know, that you are working with a solution
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
