You are here: PSPad forum > English discussion forum > Pretty good solution for SFTP
Posted by: pspad | Date: 2012-05-20 19:45 | IP: IP Logged
PSPad supports FTPS only, not SFTP.
Posted by: atomik | Date: 2012-05-20 20:24 | IP: IP Logged
pspad:PSPad supports FTPS only, not SFTP.
Thanks. I've searched forum (searching does work now) for SFTP. As advised I've used WinSCP+PSPad as default editor. It does work pretty good.. but.. it would be great to have SFTP on board here wouldn't it?
Tom
Posted by: furashg | Date: 2013-01-16 21:38 | IP: IP Logged
Did this ever get solved? It would be great if the SFTP thing works. I'm using WinSCP now with PSPad set as the editor
Posted by: kr37 | Date: 2015-06-22 04:58 | IP: IP Logged
This link has my solution with a free tunneler program, so you use PSPad like normal, but the tunneler encodes it to SFTP. Very simple to set up. The only thing would be it probably can't do it to different domains at the same time, but maybe it can.
The link just says forum.pspad.com, but goes to the right article.
