You are here: PSPad forum > English discussion forum > Drag & Drop from tool panel not allowed
Posted by: Joel | Date: 2023-07-23 00:11 | IP: IP Logged
I'm using PSPad 5.0.7 (775) on Windows 11 for the first time. When I try to drag an image file from the tool panel into the editor, it will not allow it. It shows a circle with the line through it, to indicate that I cannot do it.
Is there a setting to allow this action? I am not running PSPad in administrator mode.
Posted by: pspad | Date: 2023-07-23 06:05 | IP: IP Logged
This problem should be fixed in the last build 5.5.1 - developer forum.
Posted by: Joel | Date: 2023-07-23 14:15 | IP: IP Logged
Thank you. I am currently using 64-bit version. Will it break if I install 32-bit over it? Or should I install in a new directory?
Posted by: pspad | Date: 2023-07-23 16:41 | IP: IP Logged
Install 32b version over your 64b version. 32b version is more stable
