You are here: PSPad forum > English discussion forum > ftProgress
ftProgress
#1 ftProgress
Posted by: mce | Date: 2023-06-20 12:38 | IP: IP Logged
Hi Jan,
I just upgraded to 5.5.1 from 4.6.1 which I used for many years before.
I noticed a difference in the ftProgress parser, it seems to be case sensitive now, before it wasn't for example in 4.6.1 regardless if I have PROCEDURE or Procedure or procedure and FUNCTION or Function or function the output in the Code Explorer was same. But in 5.5.1 if I have
PROCEDURE name , the Code explorer shows PROCEDURE name
but if it's procedure name ,then it shows only the name as before
(under the "Procedure" tree)
For FUNCTION it shows for example
FUNCTION name returns character
for function it shows
but before regardless if FUNCITON or function it showed only
(under the "Function" tree)
Is there a way to revert to the old behavior?
Thanks,
Cristian
#2 Re: ftProgress
Posted by: pspad | Date: 2023-06-20 13:26 | IP: IP Logged
I will check it.
