You are here: PSPad forum > English discussion forum > Tab-to-Space: how to insert a literal Tab if needed sometimes?
Posted by: idefix2 | Date: 2021-08-13 12:14 | IP: IP Logged
Hi
I have configured PSPad to insert spaces in the text when I enter tab. That is the way I need it 99.9% of the time.
However, there are exceptions when I want to insert a tab character to the text. Is that possible without changing temporarily the PSPad configuration and changing it back afterward?
It looks like I can't even insert a tab character from the clipboard, it's also converted to spaces.
Edited 2 time(s). Last edit at 2021-09-10 08:49 by Stefan.
Posted by: Vany | Date: 2021-09-03 12:10 | IP: IP Logged
the only way I have found is to replace via Sear and Replace dialog, search for your chosen char, replace by '\t', check regex and choose selected text only to be sure you might check the confirm each.
Posted by: vbr | Date: 2021-09-03 18:14 | IP: IP Logged
idefix2:HiI have configured PSPad to insert spaces in the text when I enter tab. That is the way I need it 99.9% of the time.
for rare usage of tabs, I'd use the already mentioned trick with regex replacement with \t
For convenience, a script can be used to handle this, cf. the proposed code for one previous request:
there are also other suggestions for handling tabs with different settings.
(However, pasting a real tab from elswhere via clipboard works for me normally too.)
hth,
Posted by: pspad | Date: 2021-09-03 18:58 | IP: IP Logged
For converting tabs to spaces is action in the menu Edit.
